Home › Forums › Product Discussion & Questions › BeoGram › Beogram 4002 speed issues › Reply To: Beogram 4002 speed issues
14 April 2022 at 17:31
#33796
I know the muting board had the additional pattern so it could be the same for the main board. It is easy enough for you to check. In any case the newer sealed ones are your long term solution.
