Home › Forums › Product Discussion & Questions › BeoGram › Beogram 4002 speed issues › Reply To: Beogram 4002 speed issues
4 April 2022 at 17:42
#33788
That makes sense, thanks for the explanation.
The relay are quite difficult to source I believe.
Just to rule out that part and be sure, would it be possible to short some pins from the relay and check for speed stability.
