Home Forums Product Discussion & Questions BeoGram Beogram 4002 speed issues Reply To: Beogram 4002 speed issues
#33781
alf
SILVER Member
My thoughts exactly, the motor should not run faster with a worn bearing !
running faster is not so much the problem because there are trimmer pots to adjust.
the issue is that I can not regulate sufficiently down the 33rpm speed – I can do that with the 45rpm speed though.
i only have one 45 single and can adjust that by ear as I know Bonos voice. To my ears
the speed sounds correct and steady.
the same applies to the 33rpm setting apart from the regulating down issue, which I seem unable to do…it is just a tick too fast, which I can see on a strobo disc and hear – I know McCartneys voice.
both trimmer pots are 5kOhm 25-turn Bourne trimmers.
Both 2R2 and 1R15 are on the edge of their range but it is still too fast spinning.
not sure if that is helping a diagnose ?
ALF
