Home Forums Product Discussion & Questions BeoRemote Beo4 Remote Button Mischief Reply To: Beo4 Remote Button Mischief
#33531
Guy
The symptoms do indeed sound like a contact foil fault.  However, the non working buttons share two of the same foil/PCB contact points (R1, R4 in the manual) so perhaps the connection between the keypad foil and PCB is dirty, or misaligned.  Try removing the clip, cleaning and re-assembly.
Otherwise sometime the PCBs do sometimes go wrong; I have had a couple ☹
My B&O Icons: No description available No description available No description availableNo description availableNo description availableNo description available No description available No description availableNo description availableNo description availableNo description availableNo description availableNo description availableNo description available
