Home Forums Product Discussion & Questions BeoLink Beolink 7000 issue with radio Reply To: Beolink 7000 issue with radio
#33261
Weebyx
This is because it has been configured to use 1-way mode.
If you have a 2-way Beomaster, you can enter setup and components in the Bl7000 menu, and then remove all products under AUDIO, and add them again. If your BL7000 has working 2-way receiver, it will go back to the standard 2-way screen again.
/Jacob
