Home › Forums › General Discussion & Questions › Beolab 50: Ideal BS 9000 and Beoconnect Core Setup Advice › Reply To: Beolab 50: Ideal BS 9000 and Beoconnect Core Setup Advice
Thanks for sharing your setup on BS 9000. I was originally going to plug the Beogram directly into the BS Core, but will leave it in the auxiliary of the BS9000 as you suggested. Could you clarify how you integrate the NL/ML converter into the BS Core?
Btw! I had a Beoconnect Core on loan from my dealer and decided I was better off with the BS Core for the exact reasons you mentioned regarding Mozart platform integration challenges. I also found my current Roon Nucleus to USB Audio in my BL50 was better and I will be getting a EverSolo DMP-A8 Digital Media Player Streamer which also allows native integration of Apple Music soon for Hi-res streaming.
