Home › Forums › Product Discussion & Questions › BeoSound › Options Beosound 4 connected to BeoSound 5 via Masterlink › Reply To: Options Beosound 4 connected to BeoSound 5 via Masterlink
#125655
Guy
I put this in the configuration tool and suggest the following:
Try the BS5 in A.OPT 1 – I think it should auto-configure.
And the BS4 in A.OPT 6.
But the Config Tool does also say that if you want the BS4 to be the ‘audiomaster’ and only use BS5 for N.MUSIC/N.RADIO, then audiomaster YES/NO must be set to NO on the BS5 which then disables its OPTION settings.  I hope this makes sense!
