Home › Forums › Product Discussion & Questions › BeoLink › Master Control Link (82) compatible with Beomaster 5500 and Beolink 1000? › Reply To: Master Control Link (82) compatible with Beomaster 5500 and Beolink 1000?
#124590
Madskp
GOLD Member
(2) Madskp and Guy have suggested elsewhere that the 15v power supply is only vital if you have a MCL2AV which also has passive speaker outputs and you want to use it (effectively) as an MCL2A. I’m not sure if there’s any real bonus to doing this (rather than just an MCL2A) as I don’t think it gives you independent volume control. Most MCL2AVs don’t have the passive speaker ports anyway.
Just to clarify, the MCL2AV will need an external power supply for powering it in all uses cases whether it is acting as a MCL2A or a MCL2AV since the pink wire with power in the MCL cable is not connected internally. I am not sure about the reference about this, but it might be a misinterpretation of what was meant.
(3) MCL2 is a pretty good system. In my experience (detailed here) it’s much easier to set up an MCL2 system that works as you’d like than with Masterlink (ML), especially with older kit like yours. In theory the sound quality is better with ML but you’d need good ears to tell. ML has the additional advantages of volume control on the IR-eye transceivers and the option for standard CAT6/7 cabling and RJ45 plugs though.
Just to add to this: It is possible to ad Masterlink zones to the Beomaster 5500 by use of a Beolink converter type 1611. This might give some other options for link rooms with independent volume control.
