Home › Forums › Product Discussion & Questions › BeoLink › Master Control Link (82) compatible with Beomaster 5500 and Beolink 1000? › Reply To: Master Control Link (82) compatible with Beomaster 5500 and Beolink 1000?
#124580
Madskp
GOLD Member
Yes to all the questions that you have asked in this paragraph. Be aware that the MCL2AV requires a 15v power supply so ideally look for that when you purchase. If you can find one, the predecessor to the Beolink Passive was known as an MCL2P, and had the advantage of a built in 15v power output designed to power the MCL2AV.
Actualle I have tested that a 12V power supply can also be used. However be avare that the polarity on the connector is reverse to what is common (+ is on the outside of the connector and minus is on the inside), so if you do no use an original power supply be sure to find one where the tips can switch position in order to change polarity.
