Home › Forums › Product Discussion & Questions › BeoLink › Master Control Link (82) compatible with Beomaster 5500 and Beolink 1000? › Reply To: Master Control Link (82) compatible with Beomaster 5500 and Beolink 1000?
#124575
Gustav M
SILVER Member
Thanks, I’ve managed to buy an MCL2A (relay box +transceiver) online for a good price so will try this out when I receive it.
Noted on the volume control of the MCL2AV: I saw this in one of the MCL 2 Owner’s manuals. This could be a nice feature in one of my possible linked rooms. So if I understand it correctly, I could either connect two passive speakers such as my CX50s to an MCL2AV (in which case I need to get a Beolink passive to go between) or two active ones directly to the MCL2AV? If I manage to find an MCL2AV without the transceiver, would the MCL2A transceiver that I bought also support the independent volume control?
I’m hoping to connect two rooms linked to the main room: first the one mentioned above with either the MCL2a or the MCL2AV, and then another one on the other side which may not need its own remote control ability since there’s only a glass door in between which is most often open. In this case I can maybe use the old MCL82 relay box just to hook up the additional speakers (passive ones). But how do I set up this as a “star” network, i.e. splitting the MCL cable from the Beomaster in the main room and one cable going left and another right to each of the linked rooms? In the owner’s manual there is mention of a “connection box” for this purpose but I can’t seem to find this online. Or is there an MCL cable splitter that could be used for this purpose?
