Home › Forums › Product Discussion & Questions › BeoLink › Beoactive not working in link room › Reply To: Beoactive not working in link room
#124338
paddy2042
GOLD Member
Hi Madskp
Yes everything in the main room is working DVD on BC2 plays the disc inserted either DVD or CD. Cd on Beo4 plays the Bs9000, and DTV plays the television so all seems okay in the main room.
When serviceman was here he connected the RJ45 to Masterlink to Beolink active in the link room and it seems to work fine. I asked him to use this cable in the main room to connect the Bs9000 as I only had one of these cables.
Since I have bought a second RJ45 to ML cable and connected it to link room but this time it does not seem to work. I have tried looking at option and I believe opt 6 is the way to go with the Masterlink Active but I cannot get any sound from the Link room.
I do remember once previously that the two masters did cause a problem but the technician solved this. Is it the case that now I have three masters: BC2, BS3 and Bs9000 in the same room? I wonder if there is some conflict here.
I really appreciate your suggestions and will keep working on this problem and any further ideas would be really welcome.
Paddy2042
