Home Forums Product Discussion & Questions BeoVision BeoVision 8-32 + BeoLab 3500? Reply To: BeoVision 8-32 + BeoLab 3500?
#123892
Niall Hall
Hello again, so after trying multiple option settings without any success, I decided to use an HDMI audio extractor and route the audio signal to the AV3 port with an RCA cable. And it worked! I can finally hear sound from the BeoLab 3500, and it’s actually very pleasant on its own.
There is a slight delay between the built‑in speaker on the BeoVision 8 and the BeoLab 3500, which creates a bit of an echo effect. Because of that, I won’t be using them together in the same room, but I am really happy to have confirmed that the speaker is working properly.
So now I just need the BeoLink Converter 1611 and this special cable: https://soundsheavenly.com/products/5-pin-din-to-4-x-rca-input-and-output-cable-for-b-o-naim-quad#/2-length-1m plus an audio source of course and then I should be good to go, right?
Favourite Product: BeoVision 8-32
