Home › Forums › Product Discussion & Questions › BeoMaster › Master Control Panel (MCP) 5500 Micro Switch › Reply To: Master Control Panel (MCP) 5500 Micro Switch
#123364
Greg Steinlicht
Guy, thanks for your response. I have already cleaned the microswitch, with contact cleaner, but it did not have any effect.
When you say “shorten the contacts”, does this mean squeeze in the contacts inward while turning the wheel or something else?
