The last problem (I hope) I had to deal with, was the 33 and 45 indicator lamps heating up, and burning/deforming their plastic housings.
I am a fan of LED's, primarily because of their long-life, cool operation, and highly-directional intensity, even though the associated resistor warms up while killing excess voltage.
And I also know that some purists on this forum object to the use of LED's - and that's OK. I respect their opinions, and I have learnt a lot from them!
Anyway, this LED upgrade works beautifully, and does so without adversely affecting the required voltages on the Flip-Flop circuit (called a "Vienna-Bridge" in the Service Manual). I had feared that it does affect the voltages, but further testing shows that all is OK.
In the picture, on the white plastic hinged shields, you can see the yellowish damage, due to heat emitted by the standard incandescent lamps.
Parts required (total cost less than $1)
2 x Yellow LED's 1.8V, Intensity >10,000mcd
1 x 1000 Ohm, 1 Watt metal film resistor
Some heat-shrink tubing.
Current to illuminate the 33/45 Speed lights is supplied by the Red wire.
The voltage present on the Red wire is 22.8VDC positive, which has to be reduced to about 2 Volts.
I chose a 1 Watt resistor (1/2 Watt would normally be enough), because the resistor carries the excess voltage, and heats up. Using a 1 Watt resistor, results in a much cooler resistor.
I unsoldered the Red wire from the PCB, and soldered one end of the resistor in its place.
I soldered the other end of the resistor to the Red wire.
I placed the resistor at a small distance from the white plastic housing (around the metal bolt), to eliminate the possiblity of heat damage.
The LED's must be sanded lightly to give an opaque appearance, to distribute the light evenly.
I marked the -ve lead of the LED with a blue marker, which you can see faintly on the upper edge of the LED. If the LED's polarity is incorrect, it will not illuminate.
In the picture, the LED's upper conductor is -ve, and the lower is +ve.
20 minutes work, and a great result!
