Some one on this forum made some sliders for a similar set. Anyone know the article I mean? It may have been made two years since and had lots of pictures. I just need to make a Balance control and the bottom piece from the Bass control.
John.
John.
John,
there are some slight size differences between sets. You could try to find one from a donor unit. Or, make one from the appropriate thickness of Plexiglass. This thread starts as a BM5000 slider issue but goes on to a BM3000 and the principal is the same.
/forum/imported-unmapped/beolab-5000-broken-slider#post-2193753
You could try to search the Forum as it was probably related to the restoration of a BM300 or BM4400. Quite a few used this type of slide control though. I've searched a bit but haven't found it yet.
Dave.
Thank You Dave for looking, I think that might be what I had seen. I think I will try to make one to match the other sliders I have.
John.
