Hi everyone!
Long time fan, first time poster here 🙂
I was very lucky and got my hands on a Beolab 5000 a couple of days ago, but the problem is that the volume control slider is broken. The glass is cracked and the metal part (the one that has "volume" printed on it) is gone.
Does anyone know of a way to get a hold of a replacement part?
After looking at pictures i see that maybe the sliders on the Beomaster 3000 looks similar, does anyone know if this is correct? Because I may be able to get a hold of a defect beomaster 3000 and use the sliders from that one.
The measurements of the beolab 5000 slider is:
- Width 25mm
- Height 35mm (top of the top metal part to bottom of the lower metal part)
- Depth of the metal part 6 mm
Thanks in advance
