Hi there everybody!
Just wanted to renew the belts in my beocenter 7000 tapedeck.
On first sight that seems to be a pretty quick thing. Just loosen the three screws the mechanism is mounted to the center and then pull it out.
But what about the wires in the top right corner? Is there a trick to it? They are too short to lift and turn the tape and I do not want to damage any solder joint.
That´s what I mean:
