Beomaster 6XXX / Beocord 6XXX Display red coating
Very well done! Until now I used the pure paint KARMIN for repair the display of some Beocenters and MCPs, which are only letters and digits but not those wide areas with even coating.
What about the red (and green) foils which are fitted in the old 3-D glasses
Hi all
The colored foils are a good idea but in case of the Beomaster 8000 you won't be able to get them underneath the metalframe.
At least I mounted the restored display Glas o. a BM 8000 and I'm quite satisfied with the result.
As you might know taking a picture from the display is not easy but "I did my best"
BTW. : the red lampshade of the "FILTERS" is not mounted.
