Hi dear members
The story continues
So, what we´ve got so far:
First I managed to rip of the glas from the metalframe after heating it up to about 75' C with following result, the black coating kept one half to the doublesided tape.
Login to view image
Login to view image
After that I sandblasted the metal frame looking like this:
Login to view image
I repainted the glas with some matte black coating but the new black was blacker than the original so one could see the transitions between the old and new black coating so I decided to scratch off the old coating with a metal ruler and a second for guiding around the "windows" and textmarkings as you can see on the next picture:
Login to view image
I painted again with black coat so the transitions where only visible by a close look as you can see around the text "FILTERS" and so on
Login to view image
The edges around the windows had to rapainted with a small paintbrush
Login to view image
Login to view image
After that I came to the coating on the windows with a airbrush gun. Problem is that a airbrush gun is not designed to coat larger areals so the first attempt was slightly cloudy because too less thinner.
Login to view image
Btw.: the paint is a mixture of DEKA GLASMALFARBE TRANSPARENT from 4 pices BLACK and one pice KARMIN and 5 pieces regular thinner, but you have to test the mixture by yourself for the best results depending of nozzle diameter and pressure of the airbrush.
Login to view image
In between I coated the metalframe:
Login to view image
Now to the customers display glas:
I managed to seperate the glas and metalframe with KONTAKT WL and a razorblade which had a much better result because most of the black coat stayed on the glas, only small dents which where easily to repaint without much visibility.
Login to view image
Login to view image
Login to view image
To get the red tinted coating of I took a ceran cookfield claener like this:
Login to view image
A closer look and you could see that B&O had to repaint some small scratches:
Login to view image
After cleaning I took the airbrush again this time I mixured a little bit more KARMIN into the BLACK. For me the result was very good:
Login to view image
First looks on the Beomaster where very promising,
Last work would be the gluing of tthe glas and metalframe with double sided tape.
I´waiting for a 3M 0,6 mm tape, my regular tape is 1,1 mm and a little too high.
I´ll send some pictures next week when the tape has arrived.
Kind regards and a nice 2nd advent, stay healthy
Christian
