Yvan Janin
Forum Replies Created
  • in reply to: Cartridge MMC 5000 for Beogram 4000? #70436
    Yvan Janin
    see, indeed. It’s been so long since I bought them, I don’t know if they were new and since then some wear has occurred, I suppose, even if they have a plastic protection, like a transparent cap in front. One was bought from Soundsmith and when I serviced my Beogram 4000, a black one from them was installed. I use a brush designed for this purpose to clean it, always being careful before listening to a record that I am cleaning. Should I carry out like this the same maintenance for these two reserves? Or how? And if one day I have to change the cartridge, I will ask a professional before touching anything for fear of breaking something, it is better.
    in reply to: Cartridge MMC 5000 for Beogram 4000? #70402
    Yvan Janin
    Thank you, though it sounds too technical to me.  I absolutely do not know anything in it. I couldn’t find on the net if it was compatible and both are so expensive today.
    Both are carefully put in a box provided for this purpose.
