Wojciech Herchel
Forum Replies Created
Viewing 7 posts - 1 through 7 (of 7 total)
  • in reply to: Beogram 1500 Model 5714 #72918
    Wojciech Herchel
    so nothing can be done?
    in reply to: Beogram 2400 – muting switch #71200
    Wojciech Herchel
    Thanks – I suspect I need to lift up and take out the whole top plate, not just the platter to access this switch?
    in reply to: MMC 20E cartridge stylus / Beogram 2400 #71195
    Wojciech Herchel
    Thank you!
    in reply to: Beogram 2400 – a generic question #71187
    Wojciech Herchel
    Got it, managed to take it out. The manual says the adjustment should be made with a counterbalance weight inserted though…? So I adjust, put it back in and measure and readjust if need be? stating the obvious, I can’t access the screw if the counterbalance is in…
    in reply to: Beogram 2400 – a generic question #71102
    Wojciech Herchel
    How exactly do I lift the silver counterweight? Does it slide off or something? Maybe a daft question, however I am a new to this, so wouldn’t want to break something by mistake…
    in reply to: Beogram 2400 – a generic question #70852
    Wojciech Herchel
    Hi – where is the screw though? on the outside part of the counterweight, where the slider is or on the inside – see the picture – there is a screw on the inside part of the counterweight, where I marked in white – as it is dark and was not visible on the picture.
    in reply to: Beogram 2400 – a generic question #70774
    Wojciech Herchel
    Thank you.
    Second question I have that the stylus has a tendency to drag over the record a bit – particularly on the new/modern record – when it returns to home after finishing the record or pressing Stop – is it an easy adjustment? The stylus force is set at 1.5gr, it is a MMC20E. anything else that needs adjusting?
