Thomas McDonald
Forum Replies Created
Viewing 1 post (of 1 total)
  • in reply to: 7-40 TV unable to enter OPTIONS via on screen menu #61985
    Thomas McDonald
    Thank you for your suggestion. I have since realised that the later version beo4 remote that came with the set had, not as I presumed a missing GO button but, a missing joystick with the navigation feature enabled on the set! Anyway, since managing to disable the navigation feature I can now use my other beo4s!
