theo_1980
Forum Replies Created
  • in reply to: ASE products and Ruckus Wi-Fi, daily reconnect #51574
    theo_1980
    Automatic updates are disabled. The speakers are enrolled in the beta program. I’ve asked B&O support to remove them from the beta program.
    in reply to: ASE products and Ruckus Wi-Fi, daily reconnect #51572
    theo_1980
    I’ve changed the lease time to one hour to see if the interval in the critical error log would also change, but it didn’t.
    The M3 with the fixed IP also reconnects every 24 hours.
    I’ll take it up with B&O support. Mozart based products don’t show this behavior, so I think it’s somewhere coded in the ASE product firmware.
    in reply to: ASE products and Ruckus Wi-Fi, daily reconnect #51571
    theo_1980
    You’re right, the DHCP lease time is 24 hours. I’ve changed this to 7 days and set the IP of one M3 to fixed. I’m going to monitor the behavior for a couple of days.
    But I think you’ve directed me in the right direction, so thank you 🙂
    The reason that I was looking into this, was that sometimes a speaker loses its network connection during the night and
    won’t automatically reconnect to the Wi-Fi network. It had to go through a power cycle before it was available on the network again.
