sven-inge.neij
Forum Replies Created
  • in reply to: New product launch – beosound theatre? #62428
    sven-inge.neij
    Hi Sven, To connect your BS9000 you will need a NL/ML Converter but even with this integration is not optimal. If all speakers are connected to your Theatre you cannot just press e.g. “CD” on your remote, you need to start the “CD” session on the NL/ML Converter and then “JOIN” this session with your Theatre and then you can change track etc. Alternatively you can connect one of the outputs from your BS9000 to your Theatre but then you cannot control the BS9000 through the Theatre. For your speakers to play you need to have a “Listening Position” where you speakers are acrivated.dd
    Thanks, I now have speakers plying sound.
    I have a NL/ML converter as used with my BV11, but how to start the ”CD” session on the converter
    Regards
    Sven
    in reply to: New product launch – beosound theatre? #62353
    sven-inge.neij
    Hi I did upgrade my BV11 to a Beosound Theatre with LG Panel, my intension to reuse my PL speakers, AppleTV, Samsung DVD and my BeoSound 9000.
    During setup it did found my beolab’s I don’t get any music from them!!
    Trying to figure out how to add my BS 9000!!
    Any help/pointer would be helpfully.
    Regards
    Sven
