Forum Replies Created
19 February 2026 at 12:30 in reply to: Query about 4400 top cover – grille exposes internals – is this correct? #74071
Stephen Taylor
SILVER MemberIt looks great! They are quite satisfying to work on, mainly because to me it feels like they’re balanced on a knife edge. The first one I worked it looked like the output transistors on one channel had gone O/C, then someone had replaced the fuses with higher values which completely burned some of the copper, then they’d patched the copper with what looked like 16AWG which then fried most of the driver transistors after which they put it in a cupboard. Once you get them working though they sound amazing.
Anyway thanks again for the info – put my mind at rest.
Steve
18 February 2026 at 15:57 in reply to: Query about 4400 top cover – grille exposes internals – is this correct? #73975Stephen Taylor
SILVER MemberThanks very much for getting back to me – I thought that would be the case (no pun intended) but great to have it confirmed.
Never seen a walnut case before (I assume it’s walnut) very nice indeed.
Cheers
Steve
Stephen Taylor
SILVER MemberI’m sure you’ve checked this but it’s still worth asking: do the preset still work or are they faulty too?
I’ve worked on a couple of 4400 units but fortunately the receiver components on both worked without any issues other than a failed tuning cord which I doubt is your problem.
Cheers
Steve
13 February 2026 at 11:38 in reply to: About to start my 2nd Beomaster 4400 restoration – need tuner restring advice #73664Stephen Taylor
SILVER MemberFinally fixed it – it’s similar to the arrangement in a 4000 except in a 4400 the wheel is vertically mounted so used that as a reference.
The anchor on the wheel for the spring had broken. I added a brass post and secured it in place with kiwkplastic+epoxy seal – seems very strong and works with no issues.
When I was re-stringing, the cord broke. Fixing this was not fun and required a lot of tweaking and re-stringing in order to get the correct tension. I would not look forward to doing it again!
Thanks for again for the comments, I really appreciate the help.
Steve
13 February 2026 at 11:38 in reply to: About to start my 2nd Beomaster 4400 restoration – need tuner restring advice #73665Stephen Taylor
Steve
31 January 2026 at 00:23 in reply to: About to start my 2nd Beomaster 4400 restoration – need tuner restring advice #72984Stephen Taylor
SILVER MemberThanks very much for the updates. I’ve got a few beomasters and beocenters of similar vintage so I’m going to use those as a reference although the wheel in those are mounted horizontally not vertically. The best manual I’ve found is on the radio museum but I don’t have enough points earned yet to download it. If I get a better one I’ll upload it here.
Thanks again!
Steve
13 January 2026 at 15:33 in reply to: About to start my 2nd Beomaster 4400 restoration – need tuner restring advice #72526Stephen Taylor
SILVER MemberHi Craig,
thanks for the message – would be super-grateful if you can find it.
Cheers!
Steve
10 January 2026 at 15:47 in reply to: About to start my 2nd Beomaster 4400 restoration – need tuner restring advice #72479Stephen Taylor
SILVER MemberFound this on here, not sure how I missed it before – sounds pretty reasonable:
Take off the top cover, the tuning slider has some pins glued to the tuning string, probably the glue let loose or the pins are broken, or worst case the string is broken, If the string is broken, you will need a new one, If not, tune in to a known station, set the slider exactly to the stations Mhz, with epoxy or a strong glue attach the slider to the string.
10 December 2025 at 23:29 in reply to: Simplest way to change Beomaster 4400 FM signal level lamp #71844Stephen Taylor
SILVER MemberI managed to get the bulb changed without doing any damage – it those fiddly mechanical-type jobs that scare me the most. The hardest bit for me was screwing the copper leaf spring back in place.
The oscillation problem was due to a faulty diode. I’d had to replace them all on the right-hand channel but tested them on the left and they all tested “OK” but clearly weren’t. It was basically a “process of elimination” fix because the diode were the only things that were different.
Thanks again for your help, I’m extremely grateful.
Cheers
Steve
10 December 2025 at 10:10 in reply to: Simplest way to change Beomaster 4400 FM signal level lamp #71839Stephen Taylor
SILVER MemberThanks so much for the reply, fantastic detailed advice – there’s no substitute for learning from someone who’s done it before.
I’m building myself up to doing it this weekend – a while ago I bought a Beocenter 3500 kit from Danish Sound Parts which I haven’t used yet, so I’m hoping one of the bulbs in that is a match.
I’ve been carefully testing it and the only remaining problem (apart from the lamp) is that left left channel oscillates at around 1kHz if I activate the unit with speakers connected. The only difference that I can think of is that I replaced more of the diodes in the right-hand output section than I did the left. I tested them and put the ones that passed back in – regretting that now.
Thanks again,
Steve
14 July 2025 at 14:16 in reply to: Software for single chip computers etc. contained within products. #67030Stephen Taylor
SILVER MemberFantastic – that’s worth knowing!
Thank you!
14 July 2025 at 11:03 in reply to: Software for single chip computers etc. contained within products. #67022Stephen Taylor
SILVER MemberThanks very much for the reply – great details in there.
Although creating a replacement from scratch is really appealing to me, it a hell of a lot of work. For me the hardest part would be reverse engineering the requirements. Even so I’m tempted to see how far I can get with something like a BBC microbit and a Heath-Robinson DIL adaptor.
Cheers
Steve
Stephen Taylor
SILVER MemberHi Peter,
Thanks for taking the time to reply with such great advice – I’m very grateful.
I’m in no rush with it so I’m going to take your advice and go slowly. If I learn anything that I think might be of use to others I’ll post it here.
Glad it’s OK to praise Danish Sound Parts – you really do get a personal (and very prompt) service from them.
Cheers!
Steve
