Shadi Hameed
Forum Replies Created
  • Shadi Hameed
    Thank you for your response and experience shared.  Got my weekend project to experiment with 😀!
    Shadi Hameed
    Took the plunge, bought the cable and tried it.  But didn’t work.  I was very hopeful, but I guess I need a proper analogue cable for this.
    in reply to: Front and Rear Speaker setup for Beosound Theatre #65084
    Shadi Hameed
    I initially let the room compensation do its thing.  But then tinkered with the db levels for the rear Beolab 2500 to get it to my liking.  For my seating where the rear left and right are just about near the seating pushing the db level buh 2 felt / sounded better.
    in reply to: Front and Rear Speaker setup for Beosound Theatre #64614
    Shadi Hameed
    I finally got the cables today and installed the beolab 2500 as rear speakers and the 17s in the front.  It sounds great.  But a note, the app did not have a listing for beolab 2500.  I used the beolab 4000 from the listing instead.  I thought they would have included all speakers from the late 80s onwards.  Would you recommend any other speakers that would match the beolab 2500 for the configuration?  Thanks
    in reply to: Front and Rear Speaker setup for Beosound Theatre #64464
    Shadi Hameed
    Sounds good.  I shall try it out and update on how it goes.  I will be getting the powerlink cables for the 2500 this Friday.  I shall put the 2500 as  rear surrounds and keep the 17 in the front.  Thank you for your advice.
