Severed_hand_of_skywalker
Forum Replies Created
Viewing 4 posts - 341 through 344 (of 344 total)
  • in reply to: New product launch – beosound theatre? #37395
    From what my dealer told me the only TV’s that are officially able to control the theatre and vice versa are the few LG’s listed under compatibility on the FAQ page.
    Other TV won’t have a connection port option.
    If you want to control the interface of your TV you have you use the TV’s remote and not a B&O remote or app.
    Im GUESSING though that with HDMI control turned on though you can easily tell your TV to turn on when you turn on the theatre. But like most people that’s not important to me as I use AppleTV for everything.
    in reply to: New product launch – beosound theatre? #37393
    It’s funny that there (with one or two exceptions) was no mentioning of a required ethernet connection between tv and soundcenter, as we know it from the previous LG-based Beovisions in the new install videos. Or was what we saw not LG-tv’s, but another brand, just a generic tv? We still need to know how the unit (including the LG-tv functions) is controlled with a Beoremote One. MM
    The video is marked “generic” but you can see that they used a LG C2 and matching VESA mount.
    in reply to: New product launch – beosound theatre? #37386
    My question is in the same way. Is there a solution to attach the Beosound Theatre to the Floorstand Beovision 7-55? For my seeing position the official floorstand is unfortunately too low and the solution of STB isn‘t a match for me. Thomas
    Here are all the install videos
    https://support.bang-olufsen.com/hc/en-us/articles/9396520485777-Beosound-Theatre-Installation-videos
    in reply to: New product launch – beosound theatre? #37379
    It wasn’t cheap but the theatre is exactly what I wanted from them for many years. I will be ordering the Oak version along with the motorized stand and I’m going to mount my Sony OLED on it.
    Im pairing it with BL18’s for front left and right and BL3 for the rears. For now I’m using a 3rd party sub but in the future ill probably get the 19.
    Just a note apparently if you don’t have an LG Gx it doesn’t come with the back beauty mount leaving it looking more exposed on the back.
