Hi all,
Thanks for the STL files, I will print these soon and can’t wait for the final result.
Does anyone have an STL file for the Beolab 4000 too. 😉
Also where did you go, or suggest to go for the wood frets as it seems quite precise and I doubt my local B & Q Store would be able to fulfill my requirements.
Many Thanks,
Rahul Das
