paul-mck
Forum Replies Created
  • in reply to: Wow and Flutter on Beogram 5500 #74965
    paul-mck
    I managed to resolve the height and centering issue on the platter.
    I adjusted the speed pots to see if it would make a difference to the speed, but it only got up to 31.9 RPM, so I’ll have to wait until I get the replacement belts in before i do any more with the speed pots.
    Favourite Product: Beogram 5500
    in reply to: Wow and Flutter on Beogram 5500 #74937
    paul-mck
    Thanks Martin.
    I was trying to raise up the platter so it rotated free when an LP was on, and I wasn’t getting it even all around, so started tightening (turning clockwise) the right hand screw, but now have a new problem that the platter is pulled to the left dramatically.
    Any idea of what I’m doing wrong? Or how to fix so I have even level and everything centered?
    Paul
    in reply to: Wow and Flutter on Beogram 5500 #74480
    paul-mck
    Thanks to all for the response, I’ll order a new belt and grease for the rails.
    in reply to: Beogram 5500 died #50888
    paul-mck
    Thanks for your response Martin.
    I haven’t opened up the deck yet, so not sure what burned/melted inside, but there was an odd burning smell just before it stopped.
    The belt was replaced about 8 years ago and it’s been working for years with no issues, except for a sort of metal on metal rubbing noise on the last few rotations of an LP.
    Paul
    in reply to: Beogram CD 5500 won’t play #50031
    paul-mck
    Thank you, I’ll order that kit and take it from there!
    P.
