Paul Mac
Forum Replies Created
Viewing 16 posts - 1 through 16 (of 16 total)
  • in reply to: Problem with Beogram 4002 Type 5521 #69300
    Paul Mac
    Hello Dillen. First of all, thank you for your response. Yes, I am in Argentina and sending it there is not profitable for me. And as you mentioned, something happened during the lubrication I performed, probably malpractice on my part. I found a person on Google with the same problem and they attribute it to a couple of transistors that control the voltage to the main motor and the small belt of the displacement mechanism, so I will try to check the circuit and continue looking for a solution. And also a competent technician here from that brand. Very kind!
    in reply to: Problem with Beogram 4002 Type 5521 #69238
    Paul Mac
    Thank You!.
    in reply to: Problem with Beogram 4002 Type 5521 #69227
    Paul Mac
    We agree that I’m not the right person to repair it, nor that it’s a simple tray to repair, but there’s no one here who wants to do it, so what do I do, throw it away…? On the other hand, I respectfully disagree that it caused any problems since I lubricated it in accordance with the technical service manual and with the appropriate products. I was also right that this sensor was an IR type and not an incandescent one. Furthermore, when you tell me: “1TR1 turning on 0TR1 so that 22V is sent to activate the arm motor circuit,” in reality, according to the diagram, it’s 22 volts. Your model is different from mine. The problem was always the same; there were no other problems caused by my intervention. I’m sorry for the inconvenience and thank you for your time.
    in reply to: Problem with Beogram 4002 Type 5521 #69205
    Paul Mac
    Hi, thanks for the info. I have the diagram for my equipment, and I found transistor 1TR1, but I still haven’t found 0TR1. This is the diagram I have for the Beogram 4002 5521.
    in reply to: Problem with Beogram 4002 Type 5521 #69191
    Paul Mac
    When you press start, the inward movement of the tonearm activates a switch on the slide PC board that causes it to remain on. If that is not happening you will get that problem. If you keep holding the Start button, does the arm advance to the middle as long as you hold it as it should?
              When I press the Start key absolutely nothing happens, whether I press it once and release it or if I keep it constantly pressed.
    in reply to: Problem with Beogram 4002 Type 5521 #69187
    Paul Mac
    Hi Sr. When I refer to connecting the turntable, I mean 220 volts (mains). Secondly, the turntable does absolutely nothing and has no blown fuses. And the sensor light behind the transparent ruler is an IR LED, it’s categorical. I sent you a photo of that LED; it’s not incandescent, except for the optical shutter light for the arm movement. Regarding removing the control panel and its circuit board, I work with a grounded static discharge wristband, and I specialize in electronic repair of laptop computers. Audio isn’t my specialty, but there’s no one in Argentina who understands this brand of turntable. I repeat, the turntable does absolutely nothing when plugged into the mains. And there are no blown fuses. I’m attaching a photo of the IR LED. It’s not incandescent. I already tested it with 1.5 volts, and I can only see whether it lights up or not with an infrared lens. Finally, you insist there’s no infrared LED. I’ll prove it to you. I’ve already identified the circuit. Please see the circuit in the attached photo. Sincerely.
    P.D.: My model, unlike yours, has an IR sensor, not a fluorescent one.
    I’m attaching a photo of the IR LED. It’s not incandescent. I already tested it with 1.5 volts, and I can only see whether it lights up or not with an infrared lens. That said, please tell me how I proceed from here. Do you have a flowchart?”
    in reply to: Problem with Beogram 4002 Type 5521 #69147
    Paul Mac
    Good morning, Mark. When I bought it, it worked fine, except the belt wasn’t the right one, so I cut and glued it to size while I shopped for the original on eBay. In the meantime, I moved the carriage that moves the arm from the motor until I discovered the threaded bronze shaft and the rear steel shaft. That’s all I did. Now it doesn’t do anything at all. I re-welded some of the wires, and no lights come on anymore when I plug the tray into a 20-volt outlet. Another question, the light seen in this photo, does it come from the tangential adjustment arm or from the IR diode 4D1…?
    in reply to: Problem with Beogram 4002 Type 5521 #69133
    Paul Mac
    Every time I plug the gearbox into the mains, a new problem appears. Now, no lights come on, either on the gearshift panel or the sensor. And regarding what you mentioned in your answer 69123, the relay that switches between 33 and 45 RPM may not be working properly, as it only switches at 45, not at 33. That said, and since there’s no one in Argentina who can repair my gearbox, how can we proceed with troubleshooting my gearbox? If you have a diagram, please let me know, and I’ll follow it step by step. I’m sorry for wasting your time…
    in reply to: Problem with Beogram 4002 Type 5521 #69119
    Paul Mac
    The servo belt is installed and is new. I probably removed it to take the photo. Secondly, the switch that controls 33 or 45 is working fine, and there’s continuity to the connector. Second, could someone tell me what powers the motor at 33 RPM? I’m not referring to the preset or the switch; it must be a transistor or some other component, because at 45 RPM, 3.34 VDC reaches the motor connector, but when I switch to 33 RPM, there’s no voltage. Thanks.
    in reply to: Problem with Beogram 4002 Type 5521 #69108
    Paul Mac
    Hellow hcraig244. I have it, and I also made a video. I’ll review what you mentioned in the diagram. Thanks for your input.
    in reply to: Problem with Beogram 4002 Type 5521 #69102
    Paul Mac
    Good morning. I clarify my last post. Now, when I plug the turntable into a power outlet, the speed control and rear sensor lights come on. If I set the speed to 33 RPM, it makes half a turn and stops, but if I set it to 45 RPM, the motor spins. Without the metal covers, I press the Stop key; the motor (without the belt) that moves the tangential tone arm spins. If I press Start, does it stop? With the belt in place, it doesn’t move, as if the threaded bronze shaft were stuck to the right, like it’s locked. However, if I insert the covers and set the turntable to play a record, the Start function doesn’t activate, nor do the right-left arrow keys. I do press the key to raise and lower the tone arm. I don’t know which component controls the speed, because only the motor works at 45 RPM, not 33 RPM. Try recording a video.
    in reply to: Problem with Beogram 4002 Type 5521 #69098
    Paul Mac
    Now, another problem: if I move the tangential arm by turning the motor by hand, I can raise and lower the arm. The Start works at 45 RPM, but not at 33 RPM, which controls that speed?. I took out the Transistor TIP120 and TIP125 RPM models and checked them with a tester, and they were fine.
    in reply to: Problem with Beogram 4002 Type 5521 #69089
    Paul Mac
    Thanks for your reply. The engine runs at both 33 and 45 volts, and the drive motor runs normally without the belt, and it does with the (new) belt.
    in reply to: Problem with Beogram 4002 Type 5521 #69088
    Paul Mac
    Thanks for your reply. The drive belt for the scroll motor is new and the motor works perfectly. and the threaded shaft is parallel and has not suffered any impact in such a way that it could have been damaged.
    in reply to: Problem with Beogram 4002 Type 5521 #69060
    Paul Mac
    I unsoldered the IR diode and tested it with my cell phone’s camera, and it works. And the receiver didn’t move at all (I think).
    in reply to: Problem with Beogram 4002 Type 5521 #69059
    Paul Mac
    First of all, thank you for your response. The IR diode has the correct voltage, 1.1 volts, and the receiver has 5 volts at the collector and 0.7 volts at the output.
