Yes, I was able to find everything.
Kashke has been aquired by Bourns. I contacted Bourns but their service does not really want to help – not even with datasheets. Then I found PMEC. As for Kashke 049.752, this is the direct replacement:
PMEC 102/Ve 18m 1,0 A
https://shop.pmec.cz/index.php?page=details&cat=2&prod=1062&alt=102/Ve%2018m%201,0%20A
Kashke 049.769 is a customized component – which does not exist. But I sent mine to PMEC and Josef from PMEC did all measurements and they could produce a replacement for me. Technically, it’s
102/Ve 18m 1,0A, too but it has some isolation and the winding is reversed. If you need this choke, I am sure that they will also produce this one for you.
Therefore, if you need any Kashke parts, I can highly recommend you PMEC as this company is specialized on these components and the support I received was impressive!
As for the 2 X2, these are the partnumbers. PME27MD6220KR30 and PME271MB6100MR30. I ordered them through farnell:
Attached, you can see the new parts – including the 049.769 one with the isolated pins (yellow isolation).
You must be
logged in to view attached files.
