Michel_0
Forum Replies Created
Viewing 1 post (of 1 total)
  • in reply to: Sync BeoPlay A9 2nd Gen with PC #59960
    Michel_0
    Hi and thanks for your reply.
    Could you please elaborate what “extensive range of streams” the A9 could receive?
    Using the B&O App on a Android emulator on my PC was also an idea I already thought of.
    But I did NOT find any stream, that would support simultaneously playback on the app and A9:
    • (TuneIn Radio)
    • B&O Radio
    • TIDAL
    • Spotify
    • Deezer
    • Google Cast
    • QQ Music
    Each can be controlled by the B&O app, but not played parallel on A9 and the app itself (didn’t test all services, but I assume they all work the same).
    For “normal” use cases it doesn’t make much sense to stream simultaneous playback on the app and the A9 parallel…
    So I can’t see the solution how using the app might help me out syncing playback between my PC and A9, do you?
