Michael Jaehnel
Forum Replies Created
  • in reply to: Beo 6 questions #71153
    Michael Jaehnel
    Thanks for your help. I now soldered the red cable and try again if the Beo5 will charge.
    If not, I will sell it with the technical defect on Ebay. Perhaps there is someone who can
    fix it.
    in reply to: Beo 6 questions #71130
    Michael Jaehnel
    Here I am again.
    I received the new battery yesterday and charged it overnight. I can then enter commands for about 20 seconds
    and then the control remote switches off (Message on display “recharge battery).  I have removed the red soldered cable.
    I don’t know how I can remote my B&O Ouverture. The first screen shows me  “Zones Standard” .
    Perhaps someone has an idea to fix the problem. I have attached 2 photos.
    in reply to: Beo 6 questions #70853
    Michael Jaehnel
    Thank’s Stoobie, I’ll pay attention.
    By the way, I looked on the sticker inside the BEO and see that it is the BEO 5🙈, but I think most parts are same in the BEO 6,
    except WLAN and the bigger touch screen.
    in reply to: Beo 6 questions #70834
    Michael Jaehnel
    Thank you very much for the service manual.
    I will report back when I receive the battery, once with soldered cable and when I remove it.
    The main thing is that the remote charges and keep its voltage after I put it off the charger.
    Kind regards
    Michael
    in reply to: Beo 6 questions #70815
    Michael Jaehnel
    Thank you very much for your answer and the BEO 6 Configuration Guide. That will help me a lot.
    I also find the right cable to connect it to my computer.
    Next step is to see how it works with the new battery next week.
    Perhaps someone else can help me with my first question concerning the red cable.
    Kind regards
    Michael
