Megan Henderson
Forum Replies Created
  • in reply to: Beomaster 6000 4channel Lamp Replacement #66349
    Megan Henderson
    SILVER Member
    Yeah it’s working great other than the lamps! I had gone in and fixed a few other things so this is the last thing I need to do and it’s working great as of now so I’ll know if it messes up anything haha
    in reply to: Beomaster 6000 4channel Lamp Replacement #66332
    Megan Henderson
    SILVER Member
    Ah wonderful thank you so much! Wasn’t sure if I’d need to lift that up or not. I had only found the manual that shows what all the things on the boards were and it scared me off so I’ll have to keep looking haha have fun windsurfing! How fun!
    in reply to: Beomaster 6000 4channel Lamp Replacement #66294
    Megan Henderson
    SILVER Member
    Hi
    Are you changing out all the lamps on the machine or just those that have failed? Some lamps are fitted into an enclosed plastic compartment, others are not. You will need to open the unit up to access all lamps…..check out the service manual available here for a better idea, be sure to replace the lamps according to the description provided by the supplier, the current ratings differ from location to location…….enjoy 👍
    Well I was planning to do all of them since I was already in there but I should probably just stick to the ones that failed for now! Attaching a photo of the ones I know need swapping out. I can see the bulbs and I have the correct ones ready to replace I just have no idea how to get fo them because they are in little plastic casings
