mark. hinks.
Forum Replies Created
Viewing 11 posts - 1 through 11 (of 11 total)
  • mark. hinks.
    SILVER Member
    okay scrap the previous post ..  it was  the the centre weight detector not going down far enough.
    Any way to adjust that?
    what happens now is it spins normally for a few seconds but the small lift cam rotates around to almost the start position .. record on or off .
    in reply to: beogram 3000 /1202 etc tone arm removal ?? #64856
    mark. hinks.
    SILVER Member
    i managed to unblock and thread litz wire through.
    in reply to: beomaster 3500 glass panel broken #64183
    mark. hinks.
    SILVER Member
    I feel you may be right about the addiction.
    Yes keeping my eyes open for a bm3500.
    in reply to: beocenter 9300 how to remove glass panels #62147
    mark. hinks.
    SILVER Member
    Hi Guy, it’s working and saving presets.
    I did a mother board trick as you suggested and shorted the battery.
    I also gave the battery a wiggle
    I’m so happy 😁
    No doubt I’ll be back but thank you so much for all your time and trouble over this new year.
    All I can say is, your input wasn’t wasted!
    All I have to do now is find a remote control.
    Regards to you .
    in reply to: beocenter 9300 how to remove glass panels #62143
    mark. hinks.
    SILVER Member
    Bugger, the battery is good and has power to the board.
    Tested with voltmeter.
    Anyone got any thoughts.
    Could it be resolved by something in the manual programming or maybe with a remote control.
    Otherwise I’m stumped. 🧐
    in reply to: beocenter 9300 how to remove glass panels #62139
    mark. hinks.
    SILVER Member
    Thanks..
    Ill update when done.
    in reply to: beocenter 9300 how to remove glass panels #62134
    mark. hinks.
    SILVER Member
    1. IMG20250101123307IMG20250101123918IMG20250101123256IMG20250101123243
    <!–more–>
    in reply to: beocenter 9300 how to remove glass panels #62132
    mark. hinks.
    SILVER Member
    I’ve located battery.
    I can’t see any soldering on top, is it soldered on the other side?
    Are the white pads under the battery normally there?
    Could you have a look at supplied photos.
    Thanks.. I’m very close now.
    in reply to: beocenter 9300 how to remove glass panels #62101
    mark. hinks.
    SILVER Member
    Followed instructions,
    Made a couple of errors but all buttons up and working perfectly.
    I could see the glass panels had been dodged slightly before.
    I’m now thinking the battery is probably the problem.
    Is it a desolder and solder job?
    I’ll need a second hand remote.
    My finances are pretty rubbish.
    in reply to: beocenter 9300 how to remove glass panels #62099
    mark. hinks.
    SILVER Member
    <!–more–>IMG_20241231_150319IMG20241231161203
    in reply to: beocenter 9300 how to remove glass panels #62074
    mark. hinks.
    SILVER Member
    Thanks for such a detailed and clear response.
    I’ll have a go at everything you suggest and get back to you.
    Id like to get this work of art in good condition.
    What is the situation with replacement remote control for the 9300.
    I don’t mind aftermarket .
    Thanks 🙏
