Lars Gravesen
Forum Replies Created
  • in reply to: Beosound 5 with Beolink 1611 converter #64202
    Lars Gravesen
    Thanks all, its now working even with Beoremote One, a new Audio cable did the trick 🙂  Now I am just gonna find out how to control my Samsung TV menu system with a Beoremote One if possible maybe using PUC, sound is working through HDMI eARC to 1611 controlled by the Samsung remote with a HDMI eARC audio extractor with volume control.
    in reply to: Beosound 5 with Beolink 1611 converter #64111
    Lars Gravesen
    I am getting closer 🙂 Suddenly the BS5 shows TV on the display but still no sound but noise in the speaker if I play with the 3.5 mm jack input to my  computer. So maybe its a defect AUX to 3.5 mm jack cable ? or you cannot use input from a computer ?
    This cable is on the way to me instead of the 3.5 mm jack:
    https://www.av-connection.dk/?PGr=6692&_gl=1*1xrp95q*_up*MQ..*_gs*MQ..&gclid=EAIaIQobChMI6divw5XiiwMVUkJBAh0nrgo1EAQYASABEgLYXvD_BwE&gclsrc=aw.ds&gbraid=0AAAAADzKDs3f0RHBw1cHq4N3iPsqHVsFf
    in reply to: Beosound 5 with Beolink 1611 converter #64109
    Lars Gravesen
    I use Masterlink between 1611 and BM5 ( with AM set to 2 ) and if I choose TV on Beo4 the BS5 displays A.AUX but still no sound. I have seen some BS5 saying TV on the display so I still think I am doing it wrong. I maybe thought I needed a 7 pin cable to the Aux in line but seems like thats not the case. Is there anyway to test the 1611 ( I dont even know if it is ON ) and the Masterlink cable just to verify ?
