Kurt Kremer
Forum Replies Created
  • in reply to: Beogram 5500 tonearm travel #64780
    Kurt Kremer
    Member
    Martin thank you for your reply.  After moving the carriage assemble back and forth 2 thousand times, I finally had noticed that the cables seem to be contributing (variably) to the resistance near the end of the movement.  I had done exactly what you suggested and further noticed that the clamp would not keep the cables from walking back the other way, so I pulled them out and applied a little adhesive to keep them from moving.  Additionally, the larger cable hold-down “guide” seemed to be installed upside down when compared to a couple other pictures I found on the Internet.  Flipping it seemed to give the cables a little more breathing room. I also found I could lessen the carriage movement force by adjusting the free-length of each cable (before applying the adhesive) so that they remained separated throughout their travel and not bind up against each other.  I appreciate the message that confirms this delicate movement is very finely designed. Perhaps there is a less-stiff material that could be applied instead of the current sleave?  Anyhow it seems to be much improved.  I sure focused on the wrong things for a while.  Fun to learn – I do like the table.  I’ve got a 4002 and 4004 that I like better, but this one will be a great starter table for a friend of mine.
    Kurt
    in reply to: Beogram 5500 tonearm travel #64670
    Kurt Kremer
    Member
    After cleaning and really close inspection, it almost seems like the gears are made this way. The “wear pattern” I speak of initially is too consistent without noticeable scrape marks or shards of plastic.  See movie.  It would be great if someone out there also had one apart and saw the same thing.
