Thanks Guy,
Sadly, one of the two buttons not working is the “INT” button, so a reset isn’t an option. I will try to clean the display connector again, just in case.
I’ve uploaded two photos; the first shows the two contacts I’m referring to, arrowed in red and the second shows where I believe they should touch on the PCB, also arrowed in red. These may, of course, just be bonding points!
I’d rather not bin the phone as it is, to all intents and purposes, unused.
You must be
logged in to view attached files.
