JT
Forum Replies Created
  • in reply to: MCL2AV Tone Control #66731
    JT
    SILVER Member
    Thanks a lot for checking this out. As you suggested, it seems like I have been toggling loudness off and on.
    Now its certain that local tone control is not possible, however, local loudness is also pretty cool  🙂
    When studying the schematic, I see that loudness is handled by the digital volume control IC, TC9177
    in reply to: MCL2AV Tone Control #66689
    JT
    SILVER Member
    Hello,
    Thanks for the reply.
    I also checked the circuitry, and came to the same conclusion.
    Playing the main room sources, “sound” will certainly adjust the Beomaster.
    However, sound x times seems to do something in “local mode”. (When main room BM is asleep) It appears to be one or two settings in addition to volume control.
    At the moment I am using a local non-beo source (radio+shift+7) . This doesn’t allow two-way communication via Bl5000.
    Maybe I should try to connect a data link compatible beogram or beocord.
