Johan van der Kallen
Forum Replies Created
  • in reply to: Beolab 8000 no standby on rca input #64577
    Hi LeHe,
    I want to sincerely apologise for my delayed response(s). I have finally received the keys to my first house after a 4 month struggle that was quite a roller coaster. My mind has been all over the place and all my free time has been going towards getting the house ready. It could be as much as a month before i have moved in and put my tinkering station back up.
    When i got some more time i will look into your suggestions and post my results here. I want to thank you kindly for helping me find a possible cause.
    Kind regards,
    Johan
    in reply to: Beolab 8000 no standby on rca input #64495
    Hi LeHe,
    It indeed goes into standby when the rca cable is shorted. How would one go about tracing a grounding problem?
    @jacek1313
    On the unit I tested for the grounding issue, there already is a non-original capacitor present on the pcb and this has not solved the problem. I have trouble finding out at what exact location on the diagram it is hooked up to though.
    capacitor
    Kind regards,
    Johan
    in reply to: Beolab 8000 no standby on rca input #64432
    Hi LeHe,
    Thankyou for your response.
    When switched on, there is a very quiet hum ever so slightly audible. When connecting an rca cable, it gets worse. Shorting the rca cable (which i presume is just bridging the inner and outer contact of the rca connector) the hum goes away conpletely.
    Also, when i switch input channel, the speaker makes an incredibly loud popping noise. I don’t think it’s very good for the unit but i do not know how to prevent this.
    After some more reading i found that the switch on the backside is not for switching between powerlink and rca input; they simply let you change the mode from left hand speaker to right hand. I fail to understand how this matters when only connected via a mono channel with an rca cable. Is this perhaps exclusive to the powerlink communication?
    Anyway, what i found out is that both units do not go in standby when the switch is in the bottom position, only the top position. That’s why i thought the problem only happens in rca input, and not powerlink.
    Hopefully this gives you some new info that could with thinking of a solution.
    Thanks in advance,
    Johan
