Jeffrey Girard
Forum Replies Created
  • in reply to: Beocord 5000 Capacitor Replacement advice #70949
    To recap a Beocord 5000, the following capacitors are needed:
    Bipolar 16uF/40v X2
    4000uF/25v  X2
    250uF/70v  X1
    ROE
    4.7uF/63v  X4
    22uF/6.3  X1
    47uF/16v  X1
    47uF/40  X1
    100uF/16v  X4
    220uF/10v  X1
    220uF/16v X1
    Favourite Product: Beogram 4000 and Beocord 5000
    in reply to: Beocord 5000 repaired #66646
    Thank you Peter. It took over 4 years, as the Beocord is very difficult to service, and you can’t test it without reassembling the entire unit. I find the 5000 such a beautiful cassette recorder, and am thrilled with the renewed sound quality. I appreciate your comment.
    in reply to: Beocord 5000 repaired after 3 years #66581
    Thank you guys, I appreciate your comments. Johan, I admit to be memorized by the VU meters. And indeed, somethings, like a complicated Beocord 5000 ARE worth waiting for.
    Jeff
    in reply to: Who services a Beocord 5000? #65384
    Adam,
    The sound quality went completely to bits. That is to say, it is terrible. I have a Beocord 8004, 9000, and 4500 and none required recapping to date. But one by one these 5000’s died. Worse, I had one of my three 5000’s recapped and it wasn’t enough. Plus one of my decks smells strongly of electronic burning even when turned off.
