James Powell
Forum Replies Created
Viewing 16 posts - 1 through 16 (of 16 total)
  • in reply to: Masterlink/Powerlink Tester #123238
    James Powell
    Does anyone know where I can purchase one of these masterlink testers? I am convinced my own 9000 has become corrupted in some way.
    in reply to: What are you working on now? #74116
    James Powell
    PS. Yes, via a masterlink cable
    in reply to: What are you working on now? #74115
    James Powell
    Excellent, thanks Guy. IS there any reason why the eye isnt responding to the remote or why the volume through each speaker is different? THanks
    in reply to: What are you working on now? #74083
    James Powell
    I have a Beo9000 connected to a passive and IR eye. I have beolab 3’s in another room (I appreciate this is not the ideal placement but I wanted the 9000 displayed on a wall and it had to be in the same room as where my ceiling speakers are connected to the passive).
    The IR eye will not respond to any commands from my remote.
    The left speaker is much louder than the right speaker. The sound balance is not favouring either side.
    A bit confused..
    in reply to: Beosound 9000 with 3x BeoLink Passive zone issues? #73023
    James Powell
    I’m back.
    I replaced the IR eye and also the passive – Nothing!
    I bought a new masterlink cable. Initially nothing.
    I took a speaker out of the ceiling and and made a new connection to the passive (I had disconnected everything prior to this so needed to reconnect).
    Bingo! Life. It seems to be the masterlink cable. (Although the left port speaker connection is also faulty)
    However, the IR eye will not receive anything from my controller… Also, I can only listen to the radio.. when I select “CD” no sound is played.
    Any ideas? (Thanks)
    in reply to: Beosound 9000 with 3x BeoLink Passive zone issues? #71556
    James Powell
    hi Carolpa,
    Correct, 1 is the setup. Yes, confusing, wish I had planned it better and currently not working! 😂 . I agree with your setup idea.. wish I had come on here before starting..  Thanks for your help
    in reply to: Beosound 9000 with 3x BeoLink Passive zone issues? #71524
    James Powell
    If I press A.MEM on the beo4 the 9000 will turn on and display A.TAPE – I thought this option only responded if something was connected to it? ie many years ago I had a B&O TV connected to my system and pretty sure this ran off A.MEM
    in reply to: Beosound 9000 with 3x BeoLink Passive zone issues? #71316
    James Powell
    I have ceiling speakers connected to the passive in my kitchen and the 9000 is displayed on the wall there. My beolabs are destined for another room.
    in reply to: Beosound 9000 with 3x BeoLink Passive zone issues? #71164
    James Powell
    I do not have any speakers connected directly to the 9000.
    Lead replaced with one from a B&O registered dealer. I will double check connections.
    Thanks again Madskp – much appreciated
    in reply to: Beosound 9000 with 3x BeoLink Passive zone issues? #71120
    James Powell
    When I initially set up I had the beolabs playing by using the remote and then pressed play on the ir eye. After I disconnected the beloabs I used the remote to control the ir eye.
    Only two things occurred between it working and not. I used the remote to turn on a non-b&o tv, and an electrician changed a dimmer switch.
    The IR eye had a loose connection so I replaced the lead for a new one. I find it odd how the IR eye is receiving a signal from the remote (it blinks when I hold the OFF button or blinks when I follow the process you showed above) but cannot process a proper command. I am tempted to purchase another masterlink cable to see if it is the problem?
    in reply to: Beosound 9000 with 3x BeoLink Passive zone issues? #71105
    James Powell
    No, I could use them independently of each other. I ultimately disconnected the beloabs. It is a mystery eh!
    in reply to: Beosound 9000 with 3x BeoLink Passive zone issues? #71078
    James Powell
    I have attached some beolab 3 to the 9000 and they work fine.
    in reply to: Beosound 9000 with 3x BeoLink Passive zone issues? #71060
    James Powell
    No. I have tried rewiring everything many times. The passive is in the same room as my 9000 but it didn’t affect it previously. I can only think it is an issue with the master link cable not sending a message from the passive back to the 9000?
    in reply to: Beosound 9000 with 3x BeoLink Passive zone issues? #71041
    James Powell
    the led blinked during the process but still no response to other commands. thanks again for your advice Madskp
    in reply to: Beosound 9000 with 3x BeoLink Passive zone issues? #71019
    James Powell
    I also have a beo4 remote which I prefer to use. Bizarrely, the IR eye will not respond to either remote however, if I hold done the red “off” button on the remote for about 5 seconds the red light on the IR eye blinks..
    in reply to: Beosound 9000 with 3x BeoLink Passive zone issues? #70957
    James Powell
    I have a similar issue. I have a 9000 connected to a passive and ir eye. The IR eye and passive were working fine.. then… I used my BEO5 to turn on my Samsung tv. After this my eye no longer responds to the remote or touch (ie using the buttons on the eye). I have unplugged everything a million times and replaced the cable for the eye. Any ideas? Thanks
