I don’t think I should start a new thread for this so here goes, a little take over and hijacking..
I as well own a beocenter 2300, one from 1991 with the curved laser track, and there’s an issue with the volume levels which I’m trying to sort out.
The 2300 is supposed to act only as a cd-player for my 7700, so maybe, thinking about it now, this isn’t a real issue for me?
I saw a Din to RCA-cable that I could plug into the tape 2 input on the 7700, and maybe I would be sorted? Is there a better way to hook it up to my 7700? Would prefer to use the tape 2 for streaming and movies as it is now.
I don’t see myself using active speakers with this puppy anytime soon. Sorry about thinking out loud but maybe you can tell me if there is an obvious and detrimental issue with the 2300 which is easy to fix, so I’m putting this out there.
The issue is:
The volume level is low on the right output and really low on the left. It is the same through the headphone-jack.
My guess since headphones also are affected is it’s a capacitor on the PCB, maybe even the mute one you’re speaking of? But that wouldn’t result in an imbalance, right? It would completely silence one channel?
Any help with finding the issue and possible solutions are much appreciated!
