Grgur Pauker
Forum Replies Created
  • in reply to: BeoCord 5500 – Shutting off #71173
    Grgur Pauker
    Hey pepps,
    I’ll be able to take it apart again in April. For now, I ordered all of the spare parts available for BeoCord 5500 on Danish Sound Parts (pinch rollers, belts and resistors). Some of them are for estatical reasons, like rubber feet and tires and PCB holders.
    Best,
    Pauker
    in reply to: BeoCord 5500 – Shutting off #69226
    Grgur Pauker
    I have ordered this belt from Amazon from company called “Thakker”. Do you have any better suggestion where should I order the replacement belt from? To me belt was fitting perfectly, not too tight nor too loose.
    About overload circuit, I found safety fusible resistor at Danish Sound Parts. Is that the part you mentioned/thought of?
