Welcome! If the amp works, that’s a good start. Before buying, test all inputs and outputs with speakers or headphones, check which buttons and controls fail, inspect the display, and note that dead segments are common but manageable. The lack of radio reception likely points to tuner or capacitor issues, which are often DIY-fixable. Overall, if you’re comfortable with minor repairs, it could be a worthwhile purchase.
This reply was modified 3 days, 22 hours ago by Gordon Bird.
