gary_m_walton
Forum Replies Created
  • in reply to: B & O Brochures from 1974 ( I think ) UK #41125
    gary_m_walton
    Thanks Martin.
    I think I got them about August 1974.
    All the best,
    Gary
    in reply to: B & O Brochures from 1974 ( I think ) UK #41124
    gary_m_walton
    Hello and many thanks for your reply.
    Glad you liked the brochures – I’ve had them for nearly 50 years and really glad I kept them.
    No problem at all with you doing a better job than me with the PDF’s!
    I simply put them into Word and then printed as a PDF – not the best way.
    If you need the raw jpegs, let me know and I can send them to you and look forward to a proper PDF.
    All the best,
    Gary
