Gab Kan
Forum Replies Created
  • in reply to: Beovision 10-32 cannot find HDMI signal #72522
    Gab Kan
    I left the TV with a local BO repair man. Who diagnosed a faulty main board. I haven’t spoken to him about the details yet but I guess it doesn’t come as a big surprise as the HDMI connections are on the main board.
    Would you consider it worth looking for a functioning second hand pcb-14? Are they model specific?
    Best regards.
    Gab
    in reply to: Beovision 10-32 cannot find HDMI signal #71299
    Gab Kan
    I just wanted to add that I tried the HDMI cable with another device and it is working fine.
    in reply to: Beovision 10-32 cannot find HDMI signal #71298
    Gab Kan
    Thanks for sharing, Guy. I’ve followed the instructions found in the manual. But no luck unfortunately…
    in reply to: Beovision 10-32 cannot find HDMI signal #71297
    Gab Kan
    This is how the menu is on my 10-40.
    Turn on TV: Beo4 TV
    Beo4: MENU
    Beo4: MENU (press again within few seconds)
    This gives a menu with 4 options.
    Choose ‘øvrige muligheder’ (other options)
    Choose ’tilslutning’ (connections)
    This is where you ‘map’ a AV socket (e.g. a HDMI input) to a source button on the Beo4.
    I have AV1 mapped to DTV
    AV2 mapped to V.MEM
    AV3 to DVD
    So… Those 3 buttons on the Beo4 now select either of the 3 HDMI inputs.
    Hope it helps.
    Thank you for your reply and thorough instructions. What you describe is exactly what I have done. I tried different source buttons/list items and no luck 🙁
