Forum Replies Created
19 February 2025 at 15:18 in reply to: BeoRemote one BT and LG C4 65 via Beosound Stage – TV Won’t switch on #63895
Frank2k
BRONZE MemberUPDATE: I finally got to figure out what the issue was/is.
As hunched before, for some reason, the Amazon Firestick Max 4K (FS) inserted in the HDMI1 port was causing the issue of the TV not wanting to switch on when using the BR1BT. I removed the stick, and did a 30min unplug of the power and all then worked as expected.
I’m going to try and use a different HDMI input for the FS – as it worked in the past. Just not sure if the use of a specific HDMI port and/or if it needs to be done in a certain order, in relation to the BR1 and Beosound Stage power on cycle as, again, it worked in the past, me just not knowing what the order had been in all of this (it makes sense).
10 February 2025 at 09:33 in reply to: BeoRemote one BT and LG C4 65 via Beosound Stage – TV Won’t switch on #63659Frank2k
BRONZE MemberUPDATE: Back to square one… 🙁
Cannot switch on the C4 again with the BR1BT. I’m using the same RJ45 cable as before, so I’m thinking it must be something to do with the cable rather than anything else. Going to try with a new “fresh” cable and see if that makes any difference.
Switching on (via BR1) should be as simple as : TV -> Select button (to chose the opening tv function, i.e. App, HDMI1, Live TV etc) but TV is not turning on. Worked sporadic for longer periods to all of a sudden not working. I did not make any changes to the TV settings…
Will keep this post updated as I move, slowly, forward… 🙂
7 February 2025 at 08:51 in reply to: BeoRemote one BT and LG C4 65 via Beosound Stage – TV Won’t switch on #63492Frank2k
BRONZE MemberTinusAMS – You were 100% right on the cable comment and, I’m embarrassed to say, that after I checked the connections with the new RJ45 cable, it had come lose from the Stage so no wonder nothing worked…
Looks like all is fine gain, and hope it will work going forward, as
- The LG remote is awful when you first have gotten used to the BR1,
- Going to have the C4 and Stage setup on the B&O floor stand 4547 (after I move house later this year), and as the cables are well hidden away, swapping these will be much more cumbersome going forward,
Thank you all once again for your comments and push in the right direction. Highly highly appreciated indeed…
6 February 2025 at 14:00 in reply to: BeoRemote one BT and LG C4 65 via Beosound Stage – TV Won’t switch on #63465Frank2k
BRONZE MemberThanks TinuAMS for your pointers.
I think it’s a different world between stage and Theatre, as I have no menu (in either the app or on the TV), and do not recall having seen “Settings > Sources > Tv sources > Source from stand-by” anywhere…
So, it worked for a while but then all of a sudden it stopped working again. I tried with a different RJ45 and also pulled the power on the stage. This caused a lot of additional issues.
- The BR1 is now not working at all, meaning the TV is not controllable. Went to the B&O app on the C4, re-ran it, and was told there was no connection. Cancel / Retry option were there and I tried multiple times Retry.
- The B&O app and BR1 controls the Stage fine, so I’m going to play around some more with the connections and different cables.
Not very straight forward…
1 February 2025 at 13:24 in reply to: BeoRemote one BT and LG C4 65 via Beosound Stage – TV Won’t switch on #63287Frank2k
BRONZE Member“After pressing tv, choose source, and press ok…”
THANK YOU so much Captain… Did just what you recommended and it’s now working again.
Drinks are on me next time
31 January 2025 at 13:30 in reply to: BeoRemote one BT and LG C4 65 via Beosound Stage – TV Won’t switch on #63254Frank2k
BRONZE MemberQuick Update and follow up question(s)…
For some strange reason it started working, meaning I could switch on the Stage and TV with the Beoremote, but then all of a sudden it stopped, and back to square one.
When I press “TV” on the BeoRemote One BT, the Beosound Stage turns on (two white lights) but the TV remains off. I use the LG remote to switch on the TV, and all the TV functions work as expected with the B&O remote, and same when I go to switch off the system.
I have not the faintest why the only function (Turn system on) doesn’t work when everything else does (and that it did work for 2 weeks or so)….
Just to make sure Im not doing anything wrong: What should the screen on the Remote show before I can switch TV and the Soundbar on by pressing TV? I have tried multiple (HDMI 1, Live TV, SIPTV App etc etc), or is there another sequence of buttons I should press before the signal is read correctly by the Beosound Stage and LG C4 TV?
