bo_bod
Forum Replies Created
Viewing 1 post (of 1 total)
  • bo_bod
    Hi thanks, I’ll look into the replacement supports. I may try some 3D printed or home made solution as an experiment and will keep everybody posted.
    Regarding the cap C2103, I replaced with a random chinese one with same values I had laying around, I know there is a lot of discussion especially in a French forum about using an original one but thought it was a pedantic discussion … I kept the original and will refit it if ESR and capacitance values are still spot on.
    Edit : Cap c2103 it was tested : 37µF with ESR 6 Ohm so I guess it is toasted !
