Emma Kitley
Forum Replies Created
Viewing 6 posts - 1 through 6 (of 6 total)
  • in reply to: Beogram 5500 to Kanto YU5 speaker set up help #69885
    Emma Kitley
    So happy to report that with the new DIN to RCA cable from Sound Heavenly, the record player works! Luckily there doesn’t appear to be any extra hum, (thank you Mark for the suggestion though)
    Thank you so much to everyone for all your help – I never ever would’ve gotten it working if it weren’t for you all!
    While playing records today, we got some smiles from our son ❤️
    in reply to: Beogram 5500 to Kanto YU5 speaker set up help #69836
    Emma Kitley
    Hi Yann, Mark and Nebojsa,
    Thank you so much for your continued help an invaluable – I am so appreciative! Apologies for my slow response, I am juggling trying to get this record player to work, while caring for my newborn baby!
    In the first instance I have bought a new DIN to RCA cable from Sounds Heavenly as it does seem that B&O pins are wired differently – fingers crossed this works… will keep you posted!
    Thanks so much again, Emma
    in reply to: Beogram 5500 to Kanto YU5 speaker set up help #69776
    Emma Kitley
    I bought a line level booster but unfortunately this hasn’t worked, still just receiving static…
    in reply to: Beogram 5500 to Kanto YU5 speaker set up help #69717
    Emma Kitley
    I have read that I might need a specific Beogram DIN to phono cable? But not sure why that would be…
    in reply to: Beogram 5500 to Kanto YU5 speaker set up help #69716
    Emma Kitley
    I did try this initially, but no luck, and after some research it appeared that the 5500 doesn’t have a pre-amp built in so others had bought an external one…
    in reply to: Beogram 5500 to Kanto YU5 speaker set up help #69711
    Emma Kitley
    Thank you so much!
